Warning light
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
Just been out to check over the zed and after running for a couple of minutes the engine warning light has come on. Any ideas what could cause this? The engine seems to be running OK, but I cannot test drive it because I am in sheilding!
Sean Hilton
Saffron Waldon
1.9 Roadster
morning You,
am assuming all was all ok last time you used car, think if I had EML light on would probably see what DTC,s are stored, make a note of them , clear codes and then start engine and see if they come up again, if so then investigate the area indicated
Dalek
Z3 2.2i Auto
morning You,
As soon as I can I will put the code reader on it. I am not able to use it for 12 weeks anyway.
colb
Newport, South Wales,UK
Yes, code reader to point you in the right direction, could be a cam sensor or an air leak, thats what seems to be the usual issues.
