Upgrading clock to obc
PSD
Tickhill, Doncaster
1999 MK1 Z3 1.9
Hi guys,
I have pre facelift z3 with a digital clock. I read that you could do a straight swap with a OBC. Having taken out the clock the connection is significantly different. Had anyone ever done this successfully, or maybe my plans are scuppered!
Thanks for any advice.
Brian4
Near Grantham
Z3 3.0i Auto
There could be another connector taped up out of the way. Our is the facelift so different OBC but it has both connectors for the OBC and clock.
Don't for get you will also need the OBC stalk for the left side. It has a push button with BC printed on the end.
  • Like
Reactions: PSD
PSD
Tickhill, Doncaster
1999 MK1 Z3 1.9
OK thanks Brian. I could not see anything obvious around the area. Will have to take another look.
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
Doesn't the OBC give you fuel readings and outside air temp and whatnot? Surely you can't just plug one in and expect any reading except the clock right? I really don't know about this :)
mrscalex
Swindon & Swansea
The wiring harness should be there for the temp probe in the vicinity of the offside horn. But you will need the probe.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
The OBC uses a different set of wiring @Cooper which may be taped up somewhere within the counsel. BMW took the short cut route and wired most options into the car when it was built rather than try to fit each car individually as sellers selected options. Saved them piles of time outfitting the individual cars. JIM
handsomejackuk
Australian Zeds
t
its all there... i searched for my extra connectors the other day.. best way is to remove clock and shine mobile phone / torch thourgh hole you can see then extra connectors there and if you remove the two screws holding the side kick panel on right side... steering wheel side if in u.k. you can just about wiggle you hand in there to get the connectors out... same as the temp connector under the bonnet it can be accessed without removing the left headlight its just under the airbox... i have not looked at the steering wheel column switch yet, as i dont know whether i going to go ahead with the install a yet, as there may be some calibration if its out of a different engined car... needs to be connected to inpa i think ...maybe someone else can confirm this...
handsomejackuk
Australian Zeds
t
you also need the turn signal stalk with the bc button on the end of the stalk to alter computer display settings, but you can put your own button on if you put a button across two of the terminals.. i looked at the wiring diagram last night pin 1 and pin 6 shorted emulates the bc button
Cooper
Australian Zeds
3.0i 2001
Wow. This is great. What about the fuel consumption part of the obc? Is all that also made available?
oldcarman
Canadian Zeds
It should all be available @Cooper except the outside temp until you add a sensor but I'm sure someone will correct me if I'm wrong! Oh and possibly the need to change the stalk! JIM
handsomejackuk
Australian Zeds
t
you can also emulate the bc button without adding the stalk its a short to ground pin 6 but better if you can fit the proper stalk...
Dino D
Kent
2.8 Manual
It's a while since I took my OBC out and fitted an analogue clock in its place (!) but can you not just use the buttons on the OBC to scroll through the settings without the stalk?
PSD
Tickhill, Doncaster
1999 MK1 Z3 1.9
Should have thought before! But I checked the owners manual. It confirms that you need the stalk to change the function on the obc and the s/r button is just used to change the clock and reset the obc counters. Not sure I fancy changing the stalk and messing with all the cables!
