Trickle Charger?
ZTec
Llantwit Major
Had this a couple of years now. Works well.
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
I have a CTek MXS 5.0. Highly recommended, but a little pricey. I also purchased the extension that plugs into the lighter socket to make it easier to connect.
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I think mine is called "Oxford" ? I've had it years but can't think where I had it from. You can switch charge rates from cars to bikes.
Taz
Saddleworth
Coupe
last time i was in BMW the cars in the show room where being charged with a trickle charger that was identical to a Ctek but it was badged BMW. My neighbour as a trickle charger on his Porsche, this too looks like a Ctek badged as a Porsche
andyglym
Aston Martin have the same one, just a differant badge. If it's good enough for AM .........
mwpe
Camberley
I have a Ctek MSX 5.0 not cheap but excellent for maintaining a battery over the winter.
Rambling
Just bought a CTEK charger - I having to use with an extension lead but the green LED light flashes after a bit indicating its not charging and has gone into power save mode.
Does the negative lead get fixed to the body of the car or the negative terminal like normal battery chargers? The manual isn't very clear!
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
I don't have a CTEC but would think the unit has to be attached to the negative terminal in order for it to work. Attaching to the vehicle is used while jump starting from another vehicle. HTH. JIM
andyglym
Stick it straight on the battery @Rambling, either by the crocodile clips or the spade connectors supplied. Take the bulb out of the boot if you need to.
andyglym
