ok folks here is what happened, it was midlifescrisis idea to go up fish hill, he knew it was coming, you need momentum and be in the right gear to make good the hill, it will make little if any difference how much horse power you have if your not expecting it, you will be on your back foot right to the top. so if you got humbled by a yaris, dont feel too bad, it was a trick
oh yes and the corners are tighter than they look, and if you have to lift for them then you have no chance as it will rob you of your momentum.
