The looming international incident thread (posts from door handles)
pgunter
Winchester
2.2i Sport Zedshed Special
Just enable our cousins over the other side of the pond to communicate correctly.. I thought this might help..
British term American term
accumulator battery
actuator switch or servo
Artic articulated lorry = "tractor-trailer"
baulk ring synchro ring
bonnet hood
boot trunk
bulkhead firewall
choke tube venturi
core plug freeze plug
crocodile clip alligator clip
crosshead Phillips
crown wheel ring gear
cubby box glove box or glove compartment
damper shock absorber
drive shaft half shaft or axle shaft
drop-head coupe convertible version of 2 door coupe
dumpy screwdriver short screwdriver
dynamo generator
earth ground
estate station wagon
fascia dashboard
fixed-head coupe 2 door coupe
frogeye bugeye
Gallon (Imperial) 5 US Quarts
gearbox transmission
gudgeon pin wrist pin
hood convertible top
jointing compound gasket sealant
lorry truck
mole wrench Vice grips
monocoque unibody
MOT DOT
Ministry of Transport Department of Transportation
nave plate hubcap
nose front of car
paraffin kerosene
pinking knocking or pinging
prop shaft drive shaft
petrol gasoline
prise pry
proud above or raised
quarterlight vent window
rev counter tachometer
ring gear flywheel gear, or starter gear
roadster car that only comes in a convertible style
roundabout rotary, traffic circle
RoStyle type of steel wheel (as opposed to wire)
saloon 2 or 4 door sedan
scuttle cowl
side curtains removable side windows
silencer muffler
sill rocker panel
Shooting Brake station wagon
spanner wrench
split pin cotter pin
spring washer lock washer
squab part of seat
suction advance vacuum advance
sump oil pan
thrust bearing throwout bearing
tickover idle
top gear high gear
torch flashlight
trunnion sliding or rotating joint (suspension)
Tyre tire
wheel nut lug nut
whitworth Brtish thread measuring standard
windscreen windshield
wing fender
I did something to make him happy today. Maybe he will come back cos I'm not a f*****t any more now !!:ymdevil:
pgunter
Winchester
Fenders are for bending.. and actually english Fenders are a guitar.. sorry Geeeee taaarrrrrrrr :ymdevil:=)) A wing is a body panel.. be it on a plane or a car.. lol.
pgunter
Winchester
@oldcarman We love you even if you did get away from your colonial masters.. =))
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
accumulator battery
bonnet hood
boot trunk
bulkhead firewall
choke tube venturi
crosshead Phillips
dynamo generator
earth ground
fascia dashboard
frogeye bugeye
lorry truck
monocoque unibody
MOT DOT
nave plate hubcap
nose front of car
paraffin kerosene
petrol gasoline
prise pry
scuttle cowl
silencer muffler
sill rocker panel
spanner wrench
squab part of seat
sump oil pan
tickover idle
top gear high gear
torch flashlight
Tyre tire
wheel nut lug nut
wing fender
Thanks Paul, but I'm not an American and never would want to be.. JIM
pgunter
Winchester
@oldcarman I am ever so sorry .. Americans and Canadians are never from the same mould.. Bit like Aussies and Kiwis..
oldcarman
Canadian Zeds
@oldcarman would that be in 'Québécois' or English Jim :whistle:
Around here it's both as French and English are both our official languages. In fact my boys are both fluent in French as is my granddaughter that goes to a French only school whereas the boys went to a French Immersion school. JIM
hard top
Dutch Zeds
Netherlands
In fact, the 1835 source cited refers to a foreign-speaker: "Jonathan distinguishes a Dutch or a French Canadian, by the term Kanuk".
Kanuk hippy.........:D
pgunter
Winchester
@oldcarman When I visited Toronto a few years back, The waitress had an amazing accent that sounded much more richer in tone than the french across the channel down here. They loved my quaint little English accent too. Such friendly people and very polite.
I will get back to Canada one day soon I am sure.
oldcarman
Canadian Zeds
You're welcome anytime as are all members looking for an adventure! JIM
Moved these posts from the Colour/Color coded door handle thread to keep that more on topic ;)
Thank you gents, please resume your discussion!:cool:
Gail
Nuneaton
Z4 20i MSport
So that's how the Vancouver Canucks got their name then?
