Suspension refresh
B
badman gee
Guest
Not because it needs it but because I want to look through the wheels and at the suspension and see it as new.
No rust or dirty bits.
What bits do I need please?
Shocks
Springs
Etc.
Preferably in black not mixed colours please.
Mark
z3cade
Peterborough
Euro car parts.. Go for oem replacements as you want to keep it oem.
Just clean up your springs not worth replacing if there ok
One of the things which looks really bad on my shed is the brake shield plate things. Looked really bad with rust on mine when I changed the discs on the rear.
Guess that if you are doing the shocks, it might be worth doing the top mounts as well while you are in there.
B
badman gee
Guest
I'm replacing the brake shield plates as well as the disks .
Aceman
Moderator
Wakefield
///M Roadster
Did this to mine back end of last year Mark and fitted almost as new S54 suspension which if you want to keep it OEM I would recommend as the S54 shock/springs are slightly uprated giving a better feel.
Have you had a look at DaveP's thread over on the MCoupe forum where he is systematically refreshing everything on his car, certainly worth a read.
http://www.z3mcoupe.com/forum/showthread.php?t=14947
B
badman gee
Guest
Thanks Ian,
Dave p is a real hero.
I wish I had a ramp.
Grimstead
Essex
3.0i
If there is nothing wrong with them why not pull them off, give the dampers. Lick of paint and get the springs striped and re powder coated?
