Nice treat for us in the shed today. A friends diff on his supercharged Z4 had started making very strange noises. We offered for him to drop it off and leave it with us while we looked into it.
In all her glory.
The M53B30 with a lovely charger hanging off it.
Now down to the nitty gritty, we knew we would be in for a surprise as the noises coming out the diff were awful. About an hour job getting the diff out.
First job was getting the brace off
next was the exhaust, interesting design
Next we removed the roll bar.
then onto disconnecting the half shafts and drive shaft.
There we have it she’s out.
Now for the fun part. Let’s see what’s inside. First we poured the oil out, looking a little metally.
then once we tilted the bucket….
in total we found 3 bolts. Once we looked closer we could see they backed out of the LSD unit. These should normally be locktited aswell as torqued. Can see a bolt missing from the hole.
It’s a shame as it’s caused quite a bit of destruction inside. So much so the crown and pinion will need to be changed.
Damaged the pinion gear.
So the diff is now with our local diff builder. We’ll likely source him a new unit to swap over.
In all her glory.
