For Sale Spring Pads
Antm72
South Yorkshire
15mm Nylon spring pads fit over the standard stubs replace the 5mm as standard so give a little more ride height if needed .£5 plus postage
Davyhoogy
Sunderland
'98 2.8 z3
Do please go into more detail. Haha
My rear is far too low. Wouldn't mind an extra 1cm
Antm72
South Yorkshire
These replace the current 5mm spring pad the shamffered section allows ir to sit flush with the metel pad as it slopes i ran them for a while but removed them when i changed the spring pads to different sizes to remove a slight lean.
