Sports seats and non sports seats
Kenhayes247
Meissendorf, Germany
Hello all,
Does anyone know whether the metal frames inside the sports and non sports seats are the same?
I ask because i was considering having my non sports seats re-upholstered as a sports seat. I appreciate that the adaption would require extra padding etc if its possible.
If the frames are the same, apart from the re-upholstering/padding what other differences might/are there that prevents the conversion?
Many thanks
Brian4
Near Grantham
Z3 3.0i Auto
just looking on realOEM there are parts diagrams for the foam for sports seats and standard seats but only one parts diagram for the seat and back bases, so looks as if they are the same.
spurs fan in a coupe
The tops are definately different they have little wings on the side to add the 'bucket' feel.
IainP
Hello all,
Many thanks
The frame is thick enough steel you can add any extra frame you want. I added harness reinforcement to mine but never used it after a chat with a motorsport scrutineer.
Not on a Z3, but in the past I’ve made a couple of deeper bolsters, or shoulder wings, for people using 10mm bar. It’s easy enough to bend round something to form, but sturdy enough not to bend in use. I add little gussets just because I have small dimple dies.
Fender2004
Durham
I thought I'd post this not sure if it will help? As you can see it is a standard seat.
Kenhayes247
Thanks to all for your input. I t looks as though the seat bases are common across all models but the backrests are not. The pictures you all provided were really useful. I will look to source some sports seat back rests as they are different.
Many thanks again.
Modifying some standard seats could end up being an option Ken, 1) because sport seats are silly money and 2) it could certainly be the cheaper more available option.
Kenhayes247
Hi Tony, agreed, that's the route I am heading down.
Sports seats are selling for silly money and may also need re-upholstering as well.
I will keep a lookout for some backrests I think and modify my standard seats to sports
Good luck Ken I hope you find a pair to copy.
IainP
There’s this new one on eBay
I’ll try and find the pics of the shoulder wings/bolsters I made in the past, they’re on a computer . . Somewhere.
I could quite easily bend and dimple the gussets for you, similar to the the ones on the bolsters above, I’d just need some dimensions or a drawing. And speaking of bolsters, just remembered I ‘tightened’ mine by bending them carefully inwards about 15-20mm with a big bar.
