Southern boy Z3 arm rest
SimonT
East SUSSEX
z3
Hi all,
a quick question,
has anyone fitted "southern boy's" z3 arm rest and how did you find the fitting, use and looks etc.
Cheers all,
Si
Had one of the early ones in my Z3. Nice item, quite expensive. I like the ones @Jjim, @Mazza and @Sean d have made from 3 series ones.
gookah
Shropshire
2.8 Z3
here is mine
the E46 armrest......
this one cost about £15
Chop off the bottom section:
a few screws in the side and from underneath, that can't be seen afterwards
somewhere to stick the garage door and gate remotes:
and an opening compartment too
I thought the other armrest with its scrolls, was a bit 'American Chopper'
andyglym
Yup. I have one fitted, looks and works great for me.
Jjim
Mansfield
1.9 Roadster
I did the E46 armrest in my Z3. It’s a great fit and you can cut it to the right height so your arm rests on it just where you want it.
Mine was black but I dyed in beige when I did the rest of my interior.
@Mazza also did the same and installed an E46 armrest. I dyed his from black to BMW Z3 Tanin Red to match his interior.
Mazza
Bognor Regis
:):)And here it is fitted
@Jjim also coloured my handbrake and gear shift gaiters, hockey sticks and the steering wheel.
A job to “dye” for Malc. . . . . . .
Dakar Z3
Dakar
Sunderland
Z3 2.2 , Z4 Coupe 3.0si Auto
View attachment 165109View attachment 165111
View attachment 165103View attachment 165105View attachment 165107
Hello Jim,
looking at your interior trim, can you remove the n/s dash air bag section without having to remove the full dash?
I love the 2 tone trim, I’m wishing I could do the same but with my car being Dakar with black interior, I’m limited to yellow or black, great job !!
Jjim
Mansfield
1.9 Roadster
Hello Jim,
You can remove the airbag panel cover but not the pod without removing the dash.
To remove the airbag cover, you need to remove the glove box and then unscrew the bracket with the material strap on the underside. Then you can push the cover off from underneath.
Both the passenger and drivers pods are attached to the dash by screws and some of these are underneath the vent ducting. So the dash needs to be removed to access these screws.
Dakar Z3
Dakar
Sunderland
Thank you for your quick and informative response. :thankyou:
miller1098
Carno,Welsh Wales
M
I’ve southern boys are rest it’s easy to fit no drilling or screws to put in no cutting,if you take it out you can’t tell it’s been there. it’s worked for 8 years looks good been all around Europe it also has a fitted cup holder looks oem.
Dakar Z3
Dakar
Sunderland
Hello Miller1098,
pleased to read your comments as I’ve ordered one.
john
Had 2 different types off him for 2 different cars. Both excellent and easy to fit. Top kit.
