SOLD Simota carbon fibre induction system
Jimmy Weston
Midlands
2.8 induvidual
Simota induction kit ,used less than an 100 miles,six months old like new,with original box,£240 six months ago,will fit dual vanos 2.8 late pre facelift and other dual vanos models maybe,collection only £160
Bozzy
Long Eaton.
Just out of interest, will it suit single vanos 2.8's ?.
Steve
View attachment 60246 Simota induction kit ,used less than an 100 miles,six months old like new,with original box,£240 six months ago,will fit dual vanos 2.8 late pre facelift and other dual vanos models maybe,collection only £160
Why you taking it off Jimmy? Mines single so no good but they are very sought after being so expensive new.
Jimmy Weston
Midlands
2.8 induvidual
Sorry bozzy it won't fit a single vanos unfortunately ,grumps I took it off a few weeks ago ,I've reverted back to a kn panel filter and standard air box, I'm sure it would be great for a standard dual vanos and free it up no end,but I've done M54 manifold conversion,enlarged throttle body conversion ,remap ,uprated injectors etc,and it's one thing sitting at the end off me garage ,which I don't need at the mo,I've done 8 tip runs today,and posted a few other bits on the forum today,trying to make room for a new a car project in front off the Zed ,that's all.
Antm72
South Yorkshire
Think this so will be fine for the single vanos mine has an e46 330ci one fitted as long as there's no restriction it will be good the only measurements you need are the maf size and filter size piping can be changed.:thumbsup:
Jimmy Weston
Midlands
2.8 induvidual
You could be right @Antm72 ,I'm sure it could fit a few different models,but I'm only going on what it said when I bought it,but iff u need any measurements off Maf or tubing it's no problem,ohh sorry for the upside down picture,it was taken before undoing a bottle off wine
Antm72
South Yorkshire
The inlet is slightly different on a single vanos throttle body end but not sure of the maf is a different in size.
Mine is 90mm at the filter and 80mm maf end or there abouts only had to trim the carbon fibre at the bottom to fit it .
What would I need then to adapt it to fit mine @Antm72?
Good lad! I was very tempted with this. Tony is right, you'll need an exhaust now lol!
And then a re map . . . . . . . . . :)
Bozzy
Long Eaton.
Now you'll really need an exhaust !!=))=))
I'm working on it mate,I keep telling Sara that a nice new exhaust will make the car much more fuel efficient :whistle:............think I'm wearing her down slowly :D.
Well mate if you're successful you can come over and wear Shirl down as one or two suggested I needed one after fitting my Ramair.:thumbsup:=))
Bozzy
Long Eaton.
That's easy just tell Shirl you'll be the odd one out soon if you don't get a new one ............when I'm not there as I don't like violence :nailbiting:.
Antm72
South Yorkshire
And then you can convince her that a remap is in order to make use of the new parts and save even more on fuel with the new way the car will run due to it burning fuel more efficiently :ymdevil:
I like your style Ant, you do realise you will have to explain that to Shirl too ..........................;)=))
