- Joined
- Nov 25, 2012
- Points
- 178
- Location
- Newport, South Wales,UK
- Model of Z
- Z3 M43 1.8 (1999) and Z4 E85 2.5 (2003)
Having killed the sensor drifting the corroded exhaust downpipe studs out to replace with a set of stainless bolts and nuts efforts to get the sensor out using a selection of cut away lambda sockets which only slipped off the flats and rounded them off has been a right pain.
Just bought a set of Extractor Sockets that have spiral flutes inside that bite into the flats the more force you apply to undo the sensor. I already had a smaller set but the sensors flats are 22mm my set only went up to 19mm. Got mine from Amazon but they are available on ebay at a cheaper price. Will have to cut off the top of the duff sensor to get the Extractor socket on its flats but as its dead thats not going to be a problem.
Should be able to get a breaker bar on it to exert a good amount of force on it to get it turning. Space is tight but hopeful I can get enough swing to start it moving. Will apply some heat from my Map Gas Blowlamp as well which should assist. Will report back on how these extractors perform.
Locking Wheel Nut Remover Set Stud Bolt Nut Impact Twist Socket Extractor Tool | eBay
Find many great new & used options and get the best deals for Locking Wheel Nut Remover Set Stud Bolt Nut Impact Twist Socket Extractor Tool at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
