- Joined
- Apr 27, 2012
- Points
- 100
I am repeating the offer of these seat lift mods I supplied some while ago..I will have 10 sets made up (10 cars)...they are designed and made to lift the front of the seat up slightly so as to improve the posture and comfort while driving. They decrease the tendency to slide forward on the leather seats under breaking, and also to prevent slippage and slouch whilst driving distances....the parts require absolutely no alterations to your OEM status of the car, and can be fitted by anyone with 20 minutes and a COUPLE OF spanners...no seat removal is required.
Please don't tell me you can do the same job for £5... I know all about those mods, and they are potentially lethal. The kit I supply are specifically designed to fit the Z3 cars. They are machined parts which comply to the OEM design of the seat rail and the floor of the Z3. Also, they are made from EN88 steel which is the correct material for the application. Once fitted, the security of the occupant is not compromised in any way and the safety aspect in the event of a collision is no different from the OEM status of a fitted seat.
The height by which they will raise the front mounting position is calculated to provide improved comfort without compromising the seat movement back and forth or the extent to which the backrest section can be adjusted.
I will be making up 10 sets (there are two per seat - one on each rail) The cost including postage to the UK will be £27.00. Anyone wanting a set, please PM me.
