seat belt guides
B
badman gee
Guest
Hello all,
Where is the best place to buy these?
I've just noticed my drivers one is broken :(
have looked on the oem parts list.
its on there but there isn't a part number?
is it a main dealer part only?
Many thanks
Mark
:D
Mouldy
Northampton
None at present
badman gee said:
Hello all,
Many thanks
Mark
:D
Hi Mark
Try on here;
http://www.realoem.com/bmw/showparts.do ... g=52&fg=10
I realise that you have an ///M, but I think that the same part is used across the range. I'm sure someone more knowledgable than me will confirm, though.
Good luck!!
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Hi Mark
Item 5, if you click on it then scroll down the page it shows the part number.
HTH
stevie_a
Glasgow'ish
On a similar vane
my seat belts do not go all the way back in
Is there a fix for this ? ? ?
p.s
sorry for hijacking the thread... :ymblushing:
z3cade
Peterborough
Just tape them up with silver duct tape it will look awesome and colour coded :-B :p
Seems odd that they both don't retract fully. :-\
How loose are they when you feed the belt back in?
stevie_a
Glasgow'ish
Well drivers side will almost go back may be about 4/5" in short
but the passenger side about 1/1 to 1/2 ft
how hard is it to strip down and WD40 it ?
La_vida_diver
Bideford, Devon
Z3 2.8 Roadster
sorry if I am teaching grandama to suck eggs, and you all know about it! I was exploring the site the other day and was investigating the wiki and found a wiki entry on fitting/fixing the very item "seat belt guides" I think it was written by Snoops. and I thought is was so clear and took away all the fear of undertaking the unknown that I had to PM Snoops! there are pictures and even a "thing" identified for undoing the stitching. I thought is was a great entry making the fix so much less daunting.
hard top
Dutch Zeds
Netherlands
Or you could try this......
HTH
zedder3 posted this one. (on the other site)
My Dad came up with a classic for sorting this out.
As the retainers were broken and could turn round, he drilled into each of the parts which are normally not joined together (in the gap), with a tiny drillbit, and inserted a metal pin into the holes.
This stays in place, holding the retainer together as per the above method, but using a small pin instead of the wrap. Genius!
Frank.A
Twixt Hull and York
2.8 Facelift
stevie_a said:
On a similar vane
p.s
The principle for adjusting the tension on the seat belt reel is the same as for a roller blind.The difficult part is accessing the reel.Once you have the reel out,the adjustment will be obvious.
However, if you are not adept mechanically,it's not wise to mess with inertia reel mechanisms. [-x
