I've heard that when an S50 in standard form is dyno'd it rarely reaches 321bhp.. Is this true? And why would this be?
I remember that day well.deano1712 said:My old S50 gave 301 at the dyno.
My M has been mapped and dyno'd at Evolve.. But since it's had schrick 284 cams fitted..Garythefish said:Just make sure the torque and BHP curves cross at 5250rpm
Where are you taking the car ?
My remap and dyno was done at Evolve.
Wow.. Looks like I need to book it in for the final map.. As its at stage 3HornelZ3M said:http://www.evolveautomotive.com/engine-ecu_930/tuning-packages_934/
Thats fairly interesting reading.
An interesting comment. Surely, the cross-over point is irrelevant as it is determined by the scales and units of the y-axes.Garythefish said:Just make sure the torque and BHP curves cross at 5250rpm.
You're correct, the axies will make a difference, that's why it's important that the cross over is at 5250rpm or the figures can be fudged to improve the end figure.DangerousDave said:An interesting comment. Surely, the cross-over point is irrelevant as it is determined by the scales and units of the y-axes.Garythefish said:Just make sure the torque and BHP curves cross at 5250rpm.
The most interesting thing about the Evolve read was the order of doing the upgrades -
Stage 1 = Standard + Chip
Stage 2 = Stage 1 + Exhaust + Induction + New Chip
Stage 3 = Stage 2 + Camshaft + Con-Rods & Bolts + New Chip
I suspect that very few people do this as they probably try to go straight to Stage 2.
z3cade said:Wow.. Looks like I need to book it in for the final map.. As its at stage 3HornelZ3M said:http://www.evolveautomotive.com/engine-ecu_930/tuning-packages_934/
340-350bhp sounds =p~
Good idea - did you just make this number up, or is this a trade standard that dyno tuners use?Garythefish said:the axes will make a difference, that's why it's important that the cross over is at 5250rpm or the figures can be fudged to improve the end figure.
DangerousDave said:Good idea - did you just make this number up, or is this a trade standard that dyno tuners use?Garythefish said:the axes will make a difference, that's why it's important that the cross over is at 5250rpm or the figures can be fudged to improve the end figure.
BTW, 347 is damned impressive :-bd
