bruce&kim We need to talk I wonder if they would dod a deal for two at the same time? and what about the exhaust side, and is the throttle body bored out? Looks like a pair of good find though. The inlet manifold is about the righht price but there are some little bits and peices to make it fit right. I have a write up that I will email you, that I am still investigating.
Bad news Duncan emailed the ebay guy reply was "
it has the m54 engine instead of the m52 engine so this can't be done sorry" i will keep looking though and let you know what i find
I also found this not sure if its suitable for our cars but i will try it.
"For those with M54 M54 MS43 lumps under the bonnet with throttle drive by wire ( electronic ) and not by a cable there is a reset than can be made that may improve throttle response. This is typically done if a customer complains after an a new EDK is installed - allthough it should be done as part of the procedure anyway).
Its easy and quick just 20 seconds thats all !!
1 Place key in ignition and turn to detent 1 and count for 10 seconds ( only postion 1 do not start the engine. )
2.Turn key back to 0 postion and count for another 10 seconds
3.Now turn the key all the way to detent 3 to start the engine
Thats it your throttle is now reset. this can help to improve the cars throttle response. this little trick is always worth a go if you feel the car is a little sluggish or has been bought off someone who has just gone to the shops n back in thier BM. In theroy the throttle should now adapt slightly to your driving style "
R
