Refreshed rear suspension update
Ajsbored94
I replaced a ton of stuff. Giubo, center support bearing, transmission mounts, engine mounts, roll/sway bar bushings, subframe bushings, differential bushing, trailing arms, yet I am still getting a clunking sound while shifting gears unless I rev match perfectly.
I noticed after I reinstalled the drive shaft (yes I marked it so it would still be in balance) that I could push on the drive shaft and hear/feel a slight bump, however the drive shaft appeared to have no play or just enough play that I could not visibly notice it but could feel it.
Could this be the centering bushing in the drive shaft? I Didn't know there was one (first time working on a RWD car) inside of the drive shafts but it looked like it was intact and fine.
pgunter
Winchester
2.2i Sport Zedshed Special
@Lee what’s that part called in the diff ?
Evening chaps. It’s the crush sleeve in the diff that needs changing. It’s lost is elasticity. Part you need is about £10 but the diff will need to be stripped to reach it.
here’s the eBay link.
pgunter
Winchester
Thought you had the part and details. Top job. :whistle:
  • Like
Reactions: Lee
Ajsbored94
Thank you, and @pgunter ! Guess the work is not over yet lol.
