Rear trailing arm bushes....RTAB Powerflex
dva99999
Wirral
Z4 3.0 E85 Automatic
I’m considering adding polybushes to the rear trailing arms of my 2.8, due to a bodge job by a local mechanic who didn’t fit the drivers side standard bush correctly 🤬. (No point in naming because I’d never normally go to him.)
As I’ve already fitted rear crossmember polybushes but kept the diff mount as standard (also have powerflex rear ARBs) has anyone had this set up fitted and did it improve handling while reducing any rear end stresses?
I ask because as in a previous post I found that having the polybushed diff mount fitted I didn’t take into account that the crossmember and/or rear trailing arm were just rubber. This meant the boot floor and subframe chassis started to say bye bye to each other due possibly to all the stress being transferred to the diff mount. I’ve fixed that issue now, I still have the polybush diff mount and awaiting someone competent enough to press in the standard rubber one.
I’ve read #mikefishwicks post about subtle stiffening but haven’t seen anything about this set up
Currently have:
Powerflex rear ARB’S bushes
Powerflex rear crossmember bushes
standard diff mount bush
Looking at :
Powerflex rear trailing arms.
Putting the Powerflex diff mount bush back on???
Any thoughts?
TBH, I think many people fit the power flex bush in the Diff. mount simply because it can be done without removing the Diff. rear casing and losing the oil. Consider how long the original rubber bushes have lasted and think how long you need them to last for normal road use.
dva99999
Wirral
It was the diff mount bush that caused this problem, although the crossmember and rear trailing arms had standard rubber.
I wasn’t disputing that for a minute. I was simply saying that people can be lazy and tight fisted and go for the cheaper/easier option, you were unlucky that the previous owner of your car went that route (also ripping the floor apart like that comes from having had a very hard life).
dva99999
Wirral
I have to say.....it was me that fitted it 😔. I only noticed the problem after driving 200 miles, by which point there was that rhythmic noise of something catching under the rear of the car. To be fair (to myself at least) I did fit it some 3 years ago. When I inspected the car prior to buying it, there were a couple of rust spots in the boot where the spot welds were. That was over 5 years so it’s possible that the problem was there and I just exacerbated the problem by fitting the harder diff mount bush.
gookah
Shropshire
2.8 Z3
I fitted poly bushes all around, beam, diff and trailing arms..
two weeks later:
The diff bracket snapped completely,
It looked like it had been broken on one side for a while (darker colour,) but the extra stresses finished it off.
Diff bracket has been welded and strengthened, but I will be taking the whole lot out again this year and replacing with standard bushes.
The car now feels every bump and hollow and creaks from all over the place as it shakes things apart.
Great at handling, but getting a bit tiresome now.
dva99999
Wirral
two weeks later:
Ouch!!!
dva99999
Wirral
wasn't fun limping to a nearby Homebase with the diff dragging on the road, I was 20 miles from home at the time, managed to jack it up and chain it up to get me home:
You can see how the back cover had worn away, even partway up the drain plug
What effect did that have on the drive shaft and the diff itself due to the angle?
dva99999
Wirral
Have had no trouble, so no lasting effects and that was 4 years ago, it was only for about half a mile, very slowly.
I will put the standard differential bush back on as it will allow a small amount of movement with no stress to the mount. I’ve also strengthened the boot floor using a combination of a Randy Forbes inspired welded kit, aviation sealant from Airbus and doubling up by welding new plates on the existing mount holder.
dva99999
Wirral
I’m also getting primer and paint for the boot floor which will harden once dried.
D
Deleted member 15689
Guest
Poly bush does not cause this .it must have been rotten to start with
EXCUSE ME! :mad::mad: My zed, as are a lot of other owners Zeds, is fully poly bushed, wasn't due to laziness or being tight...... OEM bushes are cheaper than decent Poly bushes!
With regardS to time taken to remove the Diff casing (to fit a new standard bush) and refill with new oil and paying someone to do it for you, compared to the cost of fitting a poly bush only I would beg to differ.
dva99999
Wirral
Well I am lazy....I want to do job but in as little time as possible.
I am tight fisted....I can’t afford to pay the going rate for a mechanic to do it and rip me off.
That was the only point I was raising.:thumbsup:
It's also about performance and longevity.
Well sorry but it's a bad point. I have certainly not been tight fisted in maintaining my zeds the proof of that is on here and neither have a lot of others but nearly taken the route of preference and yes maybe ease. As the Zedshed has done a lot of the big jobs on my Zeds you may say lazy but I have gone with knowledge and expertise. 🤷‍♂️
