Rear Quater Panel Removal Help.
andyglym
Please. SitRep, wheel arch liners front and rear removed, front right quater panel removed, outer sill cover removed and all fixings bar one for the rear quater panel removed. Am I missing something? I just can't get a socket on the bolt head and spanner on the nut. :arghh:
The offending article is circled
Bottom (nut)
Top (bolt head(
Everything including the boot fixings have been removed and the panel comes away clean less this b*****d :bashhead:
Any top tips appreciated. TVM.
spurs fan in a coupe
That shouldn’t be there, only the two I’ve coloured yellow, 8mm.
might it’s had something addition put on, you might need to remove the two (blue) 10mm plastic puts and take the wing off with the bumper guides/mounts
HTH?
andyglym
might it’s had something addition put on, you might need to remove the two (boys) 10mm plastic puts and take the wing off with the bumper guides/mounts
HTH?
Thanks Andy. She has had a rear end shunt at some point in the past. The two you've highlighted in yellow have been removed since the pick. I took both of the ones circled in blue but no joy. Looks like it's just the nut and bolt that shouldn't be there needs some more thinking to remove. TVM :thumbsup:
andyglym
What you up to Andy, taking cleaning to another level?
Just checking the inner sills Paul. A bit of corrosion that needs sorting, nothing too alarming but needs doing. Outer sills look OK, minor surface corrosion only so I'll sort that too. Oh, and clean stuff whilst I'm in there ;)
