Reached the end.
Me and Graham have reached the end of the work on his Transit Connect Day Van.
Last jobs done today was fitting some slightly longer wheel studs as he's got a set of alloys for it and it was on steel wheels. We did the rear ones last weekend and the front ones today. I found I could access the rear of the drive flange after removing the callipers and disc. Working in the gap between the callipers carrier lugs I could get my air chisel (loaded with a flat ended round punch bit) to set the spline in the drive flange. Took about 40 minutes a side.
Last off we decided to detango the headlights!! They were pretty poor but look much better now.
O/S after.
N/S before.
After we finished I applied a coat of sealer (thanks Sean).
Not perfect but an hour very well spent we thought, big improvement.
