My roof latches are threaded as you can also see in the pics so wondering if it’s simple case of winding these in to pull the roof tighter ?? I have no issues anywhere else .
Thoughts anyone ??
I’ve the same problem, intermittent leak. What are the grommets you refer to? Any photos/advice pls? TysmEasiest thing to do is push the old grommet at the top of each A pillar in and fill out neatly with clear silicone. Both mine used to leak and never had a problem since.
Sorry for the delay not been on for a few days. Open the roof and the grommets are at the top of each A pillar to each side of the windscreen.I’ve the same problem, intermittent leak. What are the grommets you refer to? Any photos/advice pls? Tysm
That's it mate.Ah yes, this area. One a drain hole and the other a ‘grommet’ of sorts.
Tysm
From info & research, fill the circle and make sure the drain hole arrowed is clear of debrisAnd do what? Use black sealant? Where? Can you add red arrows so we can visualise this please?
