SOLD Pair headlights, excellent condition RHD
Z3I
Weybridge, Surrey
Fiji green 2.8
On offer an excellent clear crack free set of headlights, RHD, £80 collected or plus post, or swap LHD?
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
Hi, Do you still have them and if so, how much to send them to Derbyshire?
Regards,
Ken.
Z3I
Weybridge, Surrey
Fiji green 2.8
No problem to send them to Derbyshire, at a guess Id say around £10 by Hermes, or £14ish by Parcelforce. And yes, I still have them here! They are nice and clear, tabs in place etc!
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
Hi again, Looking into this I'm not sure if those are the correct lights for my car. I'll check up on the original spec,which is what I'm trying to achieve, before deciding what to buy.
Thanks for the quick reply,but I need to do a bit more research.
Regards,
Ken.
Z3I
Weybridge, Surrey
Fiji green 2.8
They came from a 1998 car, pre facelift, with a sidelight showing. Later lights have the sidelight blanked.
katkwak
Hucknall / Nottinham
1.9 m44
mmm let me check mine i have a 1997 could be just the job are they easy to fit
If your slightly mechanically minded easy 4 bolts and 3 or 4 bulb connections .
Although I would say if you take your headlamps out then refit you should ideally get the headlamp alignment checked to make sure still aligned correctly
katkwak
1.9 m44
i can remove my focus head light so i think i could manage this i,ll check the what left in the xmas fund lol
Z Victor 1
Formerly "Ontiken1"
Ripley,Derbyshire.
E 89 Z4 S drive 23i
There's one fiddly nut to get at, need a socket extension,preferably articulated. Just thought I'd mention it katkwak.
When you start to undo the screws (10 or 8mm self tapping screws if I recall right) try to hold the plastic "nut" from turning as this aligns the light with the bodywork and also affects the aim of the light beam too.
Z3I
Weybridge, Surrey
Fiji green 2.8
Just to say these are still available, all the mounting tabs all still good, not broken or repaired! £85 posted!
