Rebody Opinions on this please
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
My grille cowl doesn't fit the aperture in the body at the bottom. It fits at both ends but tapers to a approximately 6mm gap in the centre. I knew this would be the case and was planning to fill the gap.
However now I have trial fitted my front bumper it doesn't look bad to me. At present you can just see the packers under the foglight mounts but I can easily 'get rid' of those if needs be.
If I fill the gap, it will be difficult to profile the new edge and the cowl actually sits out by a few mm in the centre, so may actually look worse.
Looking at the pictures; would you be inclined to do something with it, or leave it as it is?
Looks OK to me, I could live with it, and to be fair the WOW factor of the finished car will take away from any small fitment issues I would say.
Have to agree with the rest leave it looks fine .
Your only picking on it as you know its there most others wouldn't give it a second look.
Stephen
Zephyr
If I was told that this is how it was supposed to be I would be ok
Pond
Spaldingski, Lincs
To be honest the bling of all the stainless does rather distract the eye to other things. I would like to close the gap as I know it's there. I will have a word with my sprayers soon and see what they think.
Zephyr
Perfectionism rarely begets perfection, or satisfaction - only disappointment.
RickyBobby
Sheffield, South Yorkshire
MSport 23i Highline
Sorry but if I was asking the question I would have already preempted the answer - it doesn't sit how it should and therefore it isn't acceptable. Irrespective of anyone's response you already know the answer ;)
At the end of the day you buy em to drive or you buy em to pose - I suspect you are in the latter camp. Nowt wrong with that but just make sure you address the appropriate target audience when posing the 'what next' scenario :thumbsup:
Pond
Spaldingski, Lincs
The only reason I asked was to get a different perspective on it. I spend a lot of my time looking at, and doing, this car so I have become 'blinkered' by things being 'just right'. It is a kit car, so I have learned there is no such thing as 'just right', or perfect.
Pond
Spaldingski, Lincs
Actually I am in a third camp. I am doing it to get satisfaction of doing it well. Therefore I will get a new stainless cowl made to fit the aperture correctly. Annoying, but necessary IMO.
RickyBobby
MSport 23i Highline
Like I said you already knew the answer - some choose the easy road unfortunately the rest aren’t that easily persuaded.
Jam03
Surrey
2.2i
I think you might be the only person who ever notices or cares. Looking good with the badges on!
IanA
Oxon
There's more to life than panel gaps.
Pond
Spaldingski, Lincs
Unfortunately, at this stage, there isn't for me. it's a personality disorder, I am sure. I could probably get some pills on the NHS.
Pond
Spaldingski, Lincs
They are just there to give me some sense of achievement. They need to come off and go back into their bubble wrap in my office, or I am sure to damage them! ;)
Duncodin
Pontrhydyrun
Z3 M44
I agree with others - nobody but you will ever know.
But then I also agree with you and, if I had nothing better to do I'd probably fix the gap.
Pond
Spaldingski, Lincs
The thing that would bother me is the unequal positioning of the lamp brackets relative to the grille,
It's the grille slats which are uneven. The light brackets are in the correct place. Weird thing is that the centre slat (with the emblem on) is pretty much spot on central, so the vertical slats must be at differing distances.
With the lights in place; they are quite big @ 6" diameter, it looks OK.
I can't get EVERYTHING re-made that is wrong, it will cost a fortune and I may as well start again! :confused:
