DABiggs
- Joined
- Sep 25, 2025
- Points
- 3
I have one of those instrument clusters that throws the EEP-1 error when it's chilly outside, resulting in the fuel, temp, and tachometer not working.  I'm fairly certain it's a solder issue somewhere on the circuit board - when I warm up the cluster and restart the car it works fine.  So it seems to me when the solder connection is chilled it contracts and doesn't connect, but when it's heated it expands and makes a good enough connection.
Today was a chilly day and I happened to cross into the low fuel range. The low fuel light came on even though the needle itself wasn't working. So whatever connection isn't working, it's only controlling the needle itself - at least for the fuel gauge. At some point I'll disassemble the cluster enough to get at the solder points and see if I can find the culprit. Has anyone had any luck figuring out where to look on the circuit board?
Any input or thoughts are welcome. Apologies if this has been discussed elsewhere, I haven't seen another thread that highlights this particular twist on the problem.
