Have needed to get the ball joints replaced on my zed ready for the spring.
Have been looking at replacing the complete arms and bushes but the bushes are in good condition and the outer joints are the ones with play.
Looking around i have seen just the ball joints for sale and thinking it was a garage only job never looked much further.
So after putting it off i looked some more and found that the tooling to do the job is available and at not much cost.
Replacing the arms for an oem set came in at a few hundred quid so my thinking was buy the tool and swap out the joints.
Managed to find the tool on Amazon at a great price £39 delivered so brought a couple of Lemforder ball joints and drop links and set about the task.
The tool....
Designed for all 3 series cars.
I thought it may be a right job and need heat etc but it turned out to work a dream.
I striped off as much as possible to allow room.
The tool fitted to the outer joint.
It was a simple as winding it up.
The joint pressed out
Totally removed.
Rejigged the adapters in the press and pressed back in
All back in
All replaced including the anti roll bar links for the price of one arm !!
Result!
The tool....
Totally removed.
All back in
Result!
