Hi Pete,
We found with the sills and side panels that they didn't take too long to remove at all. One word of warning, behind the front wheels there are two plastic nuts each side, that secure the back of the wheel arch liner to the floor pan. Soak those well with penetrating fluid for several days, before you try and unscrew the plastic nuts. :ympray: Even though the nuts are plastic, the studs rust inside them and will break off, if you don't take care. In fact anywhere that you find one of those plastic nuts, there is a possibility that the threaded stud is rusty. #:-s :-l
