New Carport
billz
Langley Mill
Before i went on our jollies (ended up not so jolly) i bought a Carport, So whilst i have been in quarantine since arriving back in the UK from Spain i set about putting it together.
First step was to mark out the position of the foot plates and make some concrete bases for the post holders to sit on. I needed 6 in total
I dug down around 11" inserted 8" M10 threaded bar and mixed and poured the concrete to then fill the bloody holes i have dug out and inserted the bars so they set in the concrete.
Then i needed to cut the posts down as these came as 2900mm long and i felt they were to high and also cutting them down by around 500mm would strengthen the structure. I have a slanted drive so the legs needed to be cut accordingly to make it level.
I worked out the rear section lengths first as these were the smallest then levelled and cut the remainder of the legs. Once the legs were in place and to correct height i then braced them with the side beams of which i needed assistance from son in law to level up the posts and fix beams in place.
I used the centre leg as my level for the rest of the braces and posts
I managed to get these all sorted yesterday and today i fixed all the roof braces into place.
Should be ready for the roof going on either tomorrow or Monday
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
That’s looks great :)
billz
Langley Mill
That looks really well made and solid :thumbsup: What are you using for the roof?
I have put on corrugated poly carb sheets at the moment,
i may change and put a wooden roof and felt it in the future
billz
Langley Mill
Need to take them to the tip but not allowed at the moment due to being in quarantine till Thursday
billz
Langley Mill
Finally finished the carport today. Just needed to put the strengtheners in and finish with some trimming
billz
Langley Mill
Well i did not like the corrugated roof (hard to make it look nice) so i have ordered a 16mm Triple Layer system. Hopefully should get it next week
