M44 / M43 Disa Valve Repair
So a couple of weeks ago my Dakar was a bit flat at lower revs plugged in the c110+ showing a disa valve activation fault.
After a bit of hunting around I came across this video showing Disa overhaul
View: https://youtu.be/5F6GTrF9hR0
What I discovered was it seems that the motor side of things is a sealed unit so as long as working it's good to go and all that really gets changed is the diaphragms so I thought I could do that.
M44 disa
MM43 Disa
Disa valve is the same on both engine bar the bolts ( which are different and not interchangeable) so bar the extra nut for dipstick removal is pretty much the same
I had a spare from Lynne's replacement engine do fitted that but rattling a bit.
Once removed I dismantled the faulty one and found that the upper diaphragm badly damaged.
After a bit of looking around I discovered the lower diaphragm relatively easy to aquire the upper seal less easily to obtain found a guy on ebay who did them but only in kit of 3 so as disa easily removed decided to remove them both to look at the condition of them
When you look through the hole the rod comes out of i could see the damage to the diaphragms .
So bought the kit of 3 seals
Upon inspection of the other 2 discovered both had play at the flap.
After reassembled greased the pin on the flap and greased the hinges on the flap have to say play in valve is much improved .
I would have to reckon based on the 3 I have seen the upper seal fail seems to be fairly common issue.
This is a link to the upper diaphragm set I bought
( link no longer active)
renaars
Can the valve rattle cuz i think mine is ratteling
and the you cant just switch the valve frome m43 to m44 ?
Yes can rattle quite badly.
M43 and m44 disa are the same bar the type of mount bolt if you look at the pictures at the start of the thread you will see the difference.
Stephen.
colb
Newport, South Wales,UK
ebay link not working
AntStark
Hampshire
2002 3.0 Sport
It is working they have just sold out
The red smaller front diaphragm is hard to come by yet seem to be the common one to disintegrate I had to buy 3 the last time they are around £11 each
New disa expensive as long as motor works rest can be overhauled
Stephen.
Zephyr
Going to try this. How many bolts are on the M43 and besides the two up, where are the rest?
Thanks.
colb
M43 diagram from Realoem. Two bolts at the top you can see and one below. Then the unit pulls out, probably best to use a new O ring when refitting.
Only 3 mounting points
This is a spare I have that I inherited after it had got something dropped on it damaging the casing I have managed to get it operational again and keep as a spare.
Stephen.
AntStark
Hampshire
2002 3.0 Sport
My parts arrived. Growing a pair at the moment.
Any last minute advise? Any tricky parts?
Can you do a post on how you get on or update this with pics ? Where were the parts from ? Thnx 😎👍
Shopenz
Hello.
I sell and rebuild Disa valves from 10 years.
These listings on ebay are mine.
Feel free to contact me for any questions and support about weaknesses of the valve.
AntStark
Hampshire
2002 3.0 Sport
Hello.
Which eBay listing is yours ?
AntStark
Hampshire
2002 3.0 Sport
Can you post a link to the listing as the prices look very different on uk eBay
