For Sale LH & RH seat components
I have stripped down a set of seats from a pre-facelift model non heated. Note: the main connectors are not the same between the facelift and pre-facelift.
* Seat frames in working order x2 £25 each
* Seat motors x4 £30 each if you send me your old motor or £60 to buy
* Seat base wiring harness x2 one has a broken button but still works
* Standard seat belt guides x2 £5 each
I also have various motor linkages and fastenings if needed.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
PM Sent
  • Like
Reactions: Lee
This should be what you need as I don't think the switch detaches from the harness. I'm heading over to Lees in a while so I'll have a look in his stock room and double check for you ;)
@zedcars i have one for the passenger side but the button has come off. If you can remove yours carefuly i can send this one over.
Call it £10 and i will stick the loom in a padded jiffy bag.
Yeah <<email address removed for security>>
I will most likly post at the weekend due to work commitments.
Thanks @zedcars I will get it posted at the weekend.
Zedcarz
Steel City of Sheffield
E85 2.5
Hi lee
Forgot to say received the loom no problem, not yet fitted though , hopefully it will sort out the problem
Thanks again
