Lamber sensor
Hammers
Hi have been told that I need a new lamber sensor . Any body know how much this would be and how hard to :coolsteer) thanks
Titan
Moderator
North North Yorkshire
sDrive35i
Lambda Sensors
Hi Hammers
AFAIK different Zeds have different numbers of lambda sensors
They are normally sited in front of the CAT with (depending model/engine) others behind it.
We need more info from you in order to be more specific.
EDIT - r37 beat me to it!
Titan
Moderator
sDrive35i
Looking at OEM you wantr one of THESE Part#8 11781247406 PROBE
However, check by putting the last 7 digits of YOUR chassis number into OEM - I've just guessed at Aug 98 M44 1.9
Coopers LINK want £177
Hammers
Thanks . My one is not an m sorry new. To all this mate
Titan
Moderator
sDrive35i
Z
zedonist
Guest
If it is the 1.9 Engine (Only other engine was a 2.8 during this period plus the M), then it is 1 Lambda Sensor and it is before the CAT, so in theory you can de-Cat and unleash the beast!:
This is the cheapest
http://www.eurocarparts.com/ecp/c/BMW_Z ... a94&000210
I assume the screw in / out and plug in, never changed mine
Jamezee
Peak District
Does this sensor sense lambs? if so did all zeds get fitted with it or was it an after MARKET thing or just a Martian mod?
Z
zedonist
Guest
I don't know, but all the wool :baa plus the fur balls from the Cat :eek:3 (closest icon to a cat) could be the cause of the restrictive exhaust system, what i do know, is that Lambda is the 11th letter of the greek alphabet.................
