- Joined
- Nov 17, 2014
- Points
- 35
- Model of Z
- Z3 3.0
Hi,
I have a 2001 Z3 3.0 which I absolutely love, but it’s at that age when random bits start going wrong.
Today, for the first time, I had a problem closing the hood. It came up about 1/3 of the way then stopped, this is an electrical issue not mechanical. After a while it sank back and I tried again and the same thing happened again. when the fault happens there is no power to the hood pump for opening or closing. It Is now happening randomly at various degrees of opening or closing so I suspect an intermittent fault with the wiring in the hood which gets bent with every operation. Any ideas?
Also, what is the purpose of the micro switch on the front left side of the hood? When does the hood motor ever need to be automatically turned off?
Thanks
Thanks
