NZ00Z3 submitted a new resource:
How to Read OBD2 Engine Data Logs - This document will guide you in reading engine data logs from scanners
Read more about this resource...Well, here it is, finally published. After 2 years of learning and 1 year in the writing here is the "How to" for reading OBD2 engine diagnostic logs.
This “How TO” will guide you through:
- Setting up your scanner to log data (generic instructions),
- Tests to run to record the logs,
- How to spread sheet the results and build the charts,
- What a good result looks like,
- What common bad results look like,
It is version 1, so there will be errors and corrections...
