Found Hard Top Screws
Low Rider
Having purchased a hard top I need the two screws that are mounted at the top of the windscreen.
BMW Number 54218410540
Torx Bolt M8x18
DavidM
Ireland
I got mine from BMW parts dept.
Low Rider
I would love to the van was in Hull again today why do you know of any good paint sprayers in the area mate
Low Rider
Get your pal to drop it off dude, I'll do it for you
And I would be happy for you to do it as I've seen the quality of your work but if I knew there was going to be another two deliveries I would but I can't see it if I'm honest.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
There was just a few posts about this very thing and I forget who had ordered a set but @t-tony was involved as I also need a set and not available here so hoping someone can pick me a set and post them to me. They were £7 I believe. I can use just bolts but these remain in the holes so I won't be trying to figure out what they are for as they bounce around in my glove box and guaranteed they will disappear in a matter of weeks! JIM
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I use standard M8 allen pins in mine. If I loose them they are about £7 per 100 rather than £7 for 2.
The Legend
Deceased
I would've if I'd ever got mine repaired and fitted. The only difference is the original ones have the "O" ring which keeps it in place and seals against water ingress.
littlefeller
evesham
the only reason these stay in place is they have a rubber o-ring around them but as you will only be removing it once a year i would just use allen bolts.
Jack Ratt
TRURO, CORNWALL
Never had a problem with water ingress and have been in some torrential downpours in mine. I can see your point though
The Legend
Deceased
That's what the "O" ring is for but I wouldn't have bothered either Garry, I doubt it really matters.
mwpe
Camberley
I asked Sopers just before Zedfest and they said that at that time BMW had 37 in stock. I thought someone was going to order a pair for Oldcarman.
I would check again but am off to Italy at 6 O'clock in the morning.
