Handbrake cables
Well I was at a loose end at work today and we were'nt too busy so I asked my boss if I could fit a pair of new handbrake cables on my car. While I was at it I took the opportunity to fit a set of hub centric wheel spacers which I brought back from California via Florida. (20mm at the rear and 14mm at the front). Also re coated my callipers with another coat of yellow while the wheels were off, would have been rude not to. The old cable "outers" we're both broken so over due for the bin.
I took a load of pictures to cover the process so if anyone would like me too I will post them later with a run down of the job?:)
What to do tomorrow? It doesn't look as though it will be much busier.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Well I was at a loose end at work today and we were'nt too busy so I asked my boss if I could fit a pair of new handbrake cables on my car. While I was at it I took the opportunity to fit a set of hub centric wheel spacers which I brought back from California via Florida. (20mm at the rear and 14mm at the front). Also re coated my callipers with another cost of yellow while the wheels were off, would have been rude not to. The old cable "outers" we're both broken so over due for the bin.
Please do post it up.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
I suspect after 13 years mine could do with changing, ill pop it in tomorrow for you tony :)
I do have a pair of (only) slightly worn ones Brian. Special price for a member.=))
I'll be pleased to Gaz, you may want to give it the once over first to make sure it's ok? Not too sure how soon I will be able to do it as our daughter Abbie is due to give birth very soon and today was a bit of a sign we think.;)
Cheers, Tony.
