As title Used but working £60 delivered to mainland UK
spurs fan in a coupe Zorg Guru (V) Supporter 3rd Party Trader Joined Dec 5, 2011 Points 175 Feb 26, 2017 #1 As title Used but working £60 delivered to mainland UK
spurs fan in a coupe Zorg Guru (V) Supporter 3rd Party Trader Joined Dec 5, 2011 Points 175 May 6, 2017 #2 Bump, got another one of these, not so rusty.
duckhunt Zorg Addict Joined Mar 14, 2017 Points 60 Location London Model of Z 2.8 May 7, 2017 #3 I just have a rubber blank over the hole. I assume fitting is fairly straightforward? Not urgent as I installed a dab antenna. Tempted though. Cheers
spurs fan in a coupe Zorg Guru (V) Supporter 3rd Party Trader Joined Dec 5, 2011 Points 175 May 7, 2017 #4 duckhunt said: I just have a rubber blank over the hole. I assume fitting is fairly straightforward? Not urgent as I installed a dab antenna. Tempted though. Cheers Click to expand... Yes pretty easy. Bit.of washing up liquid, then slide in, one nut inside that also holds the earth wire on. Then 2 plugs
duckhunt Zorg Addict Joined Mar 14, 2017 Points 60 Location London Model of Z 2.8 May 8, 2017 #5 Thanks for the reply, not as priority for the me but I'll bare it in mind
