- Joined
- Oct 26, 2014
- Points
- 181
- Model of Z
- Z4 coupe sport.
Recently had the coupe scanned by good friend engineer using his Delphi equipment. We did a few of the major components that you’d get done on your BMW service, found no faults but this was not a iss (complete system scan) as we didn’t have the time. However he loaded the program on to my spare computer so I could go through what it was capable of, in my own time. Was so impressed that I sent for a reader same day.
The Delphi scanner arrived and he came back to help me do a complete system scan which M/Agent would do, it now showed 9 faults including intermittent faults. We went through these faults which included the front wiring harness fault that I rectified last week. All the other 8 we decided were probably due to interference maintenance which hopefully will clear.
To check this we cleared all faults and I was advised to run the vehicle a few miles then re-scann which should tell us whatever faults remain will need to be dealt with. All faults were deemed to be minor and would not affect the normal safe running. Will take vehicle out ASAP and post up results.
The scanner is Bluetooth and still works if I sit on a chair in my garage 10-15 feet away, nice and dark in garage so screen lights up real nice, plus if it’s raining I’m in the dry.
RHA,Roy.
RHA,Roy.
