I was advised to keep the stock clock thing connected because apparently it has other functions, so I hid it behind the centre console (the actual clock did not work anyway) & I was strongly advised not to disconnect it. The switches for the soft top, air con, ASC were easy to move and as I have now completely removed the ASC system including the ASC butterfly valve in the intake, the ASC button has no function. You can see in some of the pictures that I replaced the old square air con switch with the better looking round button air con switch
