Failed electrics
Terry Crow
Lymm
Z3 1.9
Hi everyone my z3 1.9 automatic had a flat battery so I put on charge for 8 hours. Came back and all the electrics are dead. No interior light, no ignition, no side lights no radio, nothing. Tried jump leads to the electric point under the bonnet and earth on the suspension mount and no electrics nothing. Help!!!
colb
Newport, South Wales,UK
Did the battery accept the charge, has it got power? Check it with a Voltmeter.
If it has power then start looking at all the fuses could be a blown main fuse
Terry Crow
Lymm
Z3 1.9
Thanks for your help. I bypassed the battery by putting jump leads onto the connections under the bonnet. Im going to look at the fuse box next.
colb
Do check the battery connections are tight and clean and check out the pyro connection on the + terminal, they have been known to work loose and disconnect the power feed on that cable. Its there to disconnect the battery in a collision situation by blowing the connection apart to cut power.
Terry Crow
Lymm
Z3 1.9
Thanks I've never heard of a PYRO connection ill track it down and check it. Ive ordered a new battery delivery Monday.
colb
Terry Crow
Lymm
Z3 1.9
