EZCar Lift
andyglym
andyglym
Any possibility of dropping a gearbox using it?
Not really looked to be honest, the 2 connecting cross bars are roughly in line with the rear of the front wheels and front of the rear wheels to access underneath is pretty good.
smiffy
Lowestoft
Z3 2.8 pre-facelift in Montreal Blue
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
On a similar note, has anyone any experience of these tilting type lifts?
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/333358824084
I'm looking to drop the rear subframe out this winter and just want a bit more height than axle stands
@gookah has this type. It's brilliant, if you tilt it with the back end in the air there is more than enough room to work. You can have a creeper or stool to sit on under it whilst doing the work with plently of room. There's probably almost 5 foot of clearance under it with it on full tilt.
gookah
Shropshire
2.8 Z3
Yes I have one of those and it is brilliant.
Room to remove an exhaust, subframe and also sills,, looks like plenty of room to also remove a gearbox, but havent tried yet.
Can sit on a stool underneath and work comfortably
See video, This is still not fully up.
