Engine management problem.
mwpe
Camberley
This is not strictly Z related but it is an M54 engine. I have just changed the CCV on my E46 325 and on starting the engine I now have the EML light on and ABS. The engine starts fine but when pressing the throttle, it just hunts and will not pick up speed. I suspect the connection on the throttle body which was difficult to remove.
The code reader shows code 73, adaption engine throttle and code SE19. I plan to strip down and check all the connections again but would be interested if any of you experts out there can give advice.
These are the codes shown.
