- Joined
- Feb 18, 2016
- Points
- 231
- Model of Z
- Z3M Imola and Z4 (e89)
Just though I'd share this,
Over the years I have always shied away from using flushes, mainly from horror stories of high mileage engines in the 80s being wrecked by using them and running out the shells, I have no evidence this was true just hearsay and articles in motoring magazines etc (pre-internet days) but I've done an oil / filter change today on my Zed ready for the up and coming Euro run and decided after speaking to a few people on here that has used them, and the fact I had a sticky lifter on cold start up I decided to try one.
The oil had only been in the engine for just over 5k and though slightly dis-coloured before adding the flush, once added to the up to temp engine and run for 10 minutes on tick over and drained the oil that came out was black! Now being a bit of a sceptic I though the additive had done this to show something had happened, but removal of the filter showed that something had happen. The caramel discoloring that is always coating the inside of the housing (and is always covering everything else inside the engine, and that I normally wipe off) wasn't there in fact the inside of the housing was completely clean. So I am assuming its done a similar job else where.
I am a little surprised to be honest
So I am now of the opinion they do clean off the residues, but still not so sure you need to. I'll report if its cured the sticky lifter later on.
