I have a set of the above for sale, they are still in an unopened box and are the normal -30mm from standard springs,
£140 inc postage
£140 inc postage
I can see a deal being struck here ................................How come you're not fitting them to your 2.8 mate ?, different set up in mind maybe ?.
Hmm maybe Tony, although I always said 30mm was too bigger drop for me. They do look good sat that low to be fair.I can see a deal being struck here ................................
Too right mate and I'm already sliding .A slippery slope young Albert.
Thanks mate you're a diamondWell mate, at the very least you know where to get them fitted. Would look good though.
You sure? You do reslise hes going to need to wear a crash helmet now getting in and out everytime! Could be challenging times ahead!No, I'm not on commission either.
I have a set on the 2.8 but also ended up with this set, long storyHow come you're not fitting them to your 2.8 mate ?, different set up in mind maybe ?.
Looks like you’re on a skeleton bob heading down the ice approaching terminal velocity SteveToo right mate and I'm already sliding .
Low is good Steve, makes your drive seem faster too, which is niceHmm maybe Tony, although I always said 30mm was too bigger drop for me. They do look good sat that low to be fair.
I'm up for that.So....you're ditching the tractor look then, good man. I foresee a get together at @t-tony's Zed Shed Midlands for a fitting day
They would suit your Zed Steve.Hmm maybe Tony, although I always said 30mm was too bigger drop for me. They do look good sat that low to be fair.
So you should be I'll break them putting them on for you while Tony brews upWe'll Tony it looks like there's going to be an invasion at the midlands zed shed some time .
Thanks to me old muckers for offering to help fit them, I'm quite overwhelmed .
