Wanted Drivers side black door pull
Applied Thought
Hi,
Managed to break my drivers side door pull and can't see a way to fix it so I'm in the market for a replacement.
Thanks
Applied Thought
If anyone does have a RHD Drivers side door pull, please let me know. I'm going to end up looping some paracord round the door at this rate. I'd even consider different seats and door cards (matching and dependant on distance, price etc) as I've got the classic airbag light issue. There is a bypass on there the previous owner did but it's not curing it and I fancy a bit of a change.
spurs fan in a coupe
Where abouts are you?
mrscalex
Swindon & Swansea
Are you sure it's the handle that's broken? It can sometimes stay in one piece itself and it's the door card that breaks away. The door card can be repaired with fibreglass (I have done this fix successfully).
And I wouldn't rule out repairing your door handle if it's that which is broken. A plastic weld might be effective or even araldite.
Applied Thought
It's the part where the screw holds the top of the handle to the panel. The plastic bits can't be reconstructed. I did try to glue a washer in place but it didn't work.
Applied Thought
Still had no luck tracking one down and my attempt to fix it failed
I want to get it sorted asap as I've got loads of other things to sort before the summer.
