For Sale Door card clip carriers
Southernboy
I have 7 of the black plastic "clip carriers" as per picture below. In the pic you will see the actual white clip which locates into the door skin. The one in the pic is the only one with a white clip. The other 6 are just black carriers. All are in perfect condition and clean of any old glue / door card bits etc. So, ready to stick to your door card.
I recommend you use a glue gun to apply these to the door card. All other resins seem to have no adhesion to the plastic carrier. As you will see on the ones presently still attached to your door card, be liberal in volume and the surrounding area of the actual carrier.
To correctly position the carrier, use some water based paint on the back of the carrier after fitting a white clip. Push it into the door skin hole, then position your door card using your intact clips and press the door card against the painted "new carrier"... If not paint, then use any other marking method you can imagine...;)
£5 each excluding postage. I suggest anyone wanting these should buy them all and save on postage to any other buyers. ie. If you only need two or three, sell the others on to other members in the UK.
I estimate postage to the UK will be around £10 for one as well as all 7.
Payment via PayPal only please. PayPal acc name:- searchinc@worldonline.co.za
Cheers guys
Barry
