Damsel in distress
Mazza
Bognor Regis
Spotted and carded this Z3
Then the owner came out and caught me.
The cars name is Betty, and the owner is Liz.
Unfortunately someone has hit the rear bumper and driven off. But after a quick look may be just the rear n/s bracket and a clip.
I am sure someone on the forum, and that lives in Bognor will sort it out for a potential new forum member
Bampz
Pembrokeshire
Good spot , would that someone just have gained the knowledge to help in this job;)
What were you in when you hit it Malc?:ymdevil:
Mazza
Bognor Regis
Whats that phrase....Use it or lose it =))
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
Mazza
Bognor Regis
Been round today to have a better look and have arranged to get it sorted next week.
Noticed there are a few cosmetic things to be sorted but car is in good condition.
And the owners pride and joy.
The South Coast Zed Lean-to has its first job =))
Top man:thumbsup:
Jjim
Mansfield
1.9 Roadster
Suppose that now you've finished yours you need the next project! =))
That's why he went and made this one Jim :thumbsup:=))=))
Mazza
Bognor Regis
No still got lots of stuff to keep me occupied :)
Just fitted the wind deflector that arrived this morning...
Still got these to fit...red footwell leds
But too cold in the garage so working on the toolrack indoors.
Brain is completely addled trying to work out angles and spacings......:arghh:
Also waiting for a digital vernier to be delivered so I can measure with a bit more acuracy.
But my new bench drill turned up today so put that together and put it outside, but need to work out best positions for it and the grinder before drilling holes for hold down bolts.
No you’re right Jim......I need a new project to do in case I get bored!!!! =))
Mazza
Bognor Regis
Had the Blue Z3 called Betty in the ‘Lean-to’ today to sort out the rear bumper.
The problem....
Took the rear arch cover off and found the cause
The bracket had been pushed forward, broken the washer part of the two nuts and ended up jammed against the studs.
Sprayed the bracket with WD40 to make it easier to remove, then refitted it with new nuts ( which luckily I had a pack of] and replaced the top fixing which has also been snapped.
All realigned, put the arch cover back and job done :thumbsup:
The ‘ Lean-to ‘ has a long way to go before it will be classed as a Zedshed, but its made a start =))
Good on you mate :thumbsup:
BMBabe
Staff member
Community Admin
Aylesbury
Well done :thumbsup: good job :thumbsup: #Zedshed Bognar in the making ;)
Have they joined the forum yet
Mazza
Bognor Regis
I’m hoping that she will, but she admits she’s not to good with computers !!!
Zedshed Bognor ?.....a long way off yet =))
At least fit the deflector on the right side :D
Mazza
Bognor Regis
Hi Lee, I just copied the way it was from the picture on flea-bay where I bought it.
I’m sure Ive seen other cars with fixed behind the roll bars.
Should it be on the other side of the roll bars then ???? Easy enough to swap over......
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Mines on the back of the hoops and I see it as being the right way. Turbulence in the cab swirls behind the seats and blows into the cockpit. The wind deflector is effectively pushed onto the hops and held securely. If the deflector is in front of the hoops, the turbulence effectively tries to push it off.
Main reason though is that I can't open the cubby box if the deflector is on the front without modifying the deflector.
mwpe
Camberley
I think it is designed to go on the front side but mine is on the back side for the same reason. I am planning to make one with the bit between the hoops angled to allow the box to open.
Jjim
Mansfield
1.9 Roadster
Great work Malc :thumbsup:
Nice to see that the first job was a straight forward one. Sooo what’s next on the job card? :)
