Hi
There is always a bit of confusion about where the delineation is between the pug and play Cruise Control and the extra throttle actuator cruise control. Its best sorted using your engine type:
- M43/M44 you need the extra throttle actuator control system. Easy to do, just need more parts. E36's are the usual donors
- M52 single VANOS engines, you need the extra throttle actuator control system. Like the M44, the E36's are the usual donors
- M52TU duel VANOS engines. Plug and play, source the cruise control column stick and the small control module and plug it all in.
- M54 duel VANOS engines. Plug and play, source the cruise control column stick and the small control module and plug it all in.
Hope this helps
Regards
Murray
