Had it on mine, never used it.Really fancy having cruise control
You might be right there HT.Had it on mine, never used it.
You had a soft top too and that never got used either!Had it on mine, never used it.
It depends on the system, all systems will switch off when the brake pedal is pressed. Usually when you press the accelerator it will stay on, and when you back off the speed will drop and resume to your set speed. This works that way as far as I can tell, plus you can push/pull on the stalk to increase/decrease speed to.Question Gaz I've never had a car with cruise control. I'm guessing once the cruise control is on if you brake or use the noise pedal the cruise control turns off !
Been browsing eBay.com Steve and saw these 2 items,Question Gaz I've never had a car with cruise control. I'm guessing once the cruise control is on if you brake or use the noise pedal the cruise control turns off !
