I replaced the pump motor on my 08 Z4 without removing the roof. Now when I open the roof all is good. Roof actuates, goes into the well, led lamp goes out, motor stops. However the roof won't close. Motor runs but roof won't move. If I pick the roof up appox 1/4-1/2" then then try to close it, using the pump it does close. No problem. So now I open the roof, but stop just short of were the roof would stop automatically. But that means I drive around with that light blinking if I have the top down. Is there an adjustment or sensor that can moved to fix this?
