I have run the cheap TA Tecnix coilovers for about 8 months now and I don't seem to have any trouble with them, but maybe its just me as everybody else who has fitted them to a zed seems to have problems. Yes, they are a little harder than the previous Eibach springs I had but that was to be expected and I find the handling just as good, if not better, although this is completely my opinion.
I would fit a better kit if my budget allowed, but I thought I would give them a try as they were cheap and they do the job I wanted. I don't track the car, but do drive it daily and I still have them fitted 8 months down the line. I've got the ride height just how I wanted at the front and the handling is spot on for how I drive the car and I can live with the ride being a little harder. The only negative is that the rear springs are not the best as the adjusters don't do a lot, even on there lowest setting they are no lower than the standard ride height.
Like you say, if you like the low and slow approach and are not a spirited driver they maybe suitable. If your not prepared to spend £300 plus on a better set, but want to go low then cheap is your only option as a normal set of lowering spring just might not give you the drop you are after. You are able to buy just the front set up in the cheap kits I believe, then buy a decent set of lowering springs for the rears, as the drop and ride will be better.
@gookah also has a set fitted, complete with 19's and uprated bushes and his does ride fairly harsh, but I don't think he finds them too much of a problem even if he is old and they shake his bones around a little
