hard top submitted a new resource:
Clutch Delay Valve (CDV) removal - Clutch Delay Valve (CDV; 01’-02’ non-M Z3s):
Read more about this resource...Clutch Delay Valve (CDV; 01’-02’ non-M Z3s):
This is a Clutch Delay Valve (CDV) removal and slave bleeding procedure for a 2001-2002 2.5L or 3.0L Z3. This walk-through is intended for those who need more direction and are less familiar with such DIY projects. I used a pressure bleeder, which is not required unless you wish to follow the walk-through exactly.
Please read the entire walk-through before attempting this procedure.
Things you will need:...
